The Hubble Sector Hypothesis
Theres been something thats been daffling scientists for years, Ceers-2112 and galaxies similar to it. Why are they so mature compared to the space around them? How did the infant universe create such mature galaxies this early in its lifetime? Well, widely accepted theories say that dark matter wouldve formed galaxies life Ceers-2112, but ive made a theory which would explain the missing patches in other theories. The Hubble Sector Hypothesis:
I.
The prevailing dark matter hypothesis suggests that dense gravitational wells in the early universe accelerated the collapse of gas to form galaxies ahead of schedule. However, this framework suffers from a fatal thermodynamic and chemical constraint: gravity does not forge heavy elements.
Spectroscopic analysis reveals that Ceers-2112 is heavily enriched with metals like oxygen, nitrogen, and neon. Nucleosynthesis dictates that these elements can only be generated through consecutive generations of massive stellar lifecycles and subsequent supernova events scattered across billions of years. Even if dark matter packed gas together at hyper-accelerated speeds, it cannot bypass the absolute time required for stellar evolution. Furthermore, a dark matter cluster dense enough to force such rapid stellar replication would have inevitably drawn in surrounding matter, creating a galaxy exponentially larger than the relatively compact, baby-Milky-Way dimensions observed in Ceers-2112. Because the timeline cannot fit the chemistry, the localized native model must be challenged.
II.
Instead of looking inward, this model maps our local cosmic neighborhood as a bound multiverse cluster designated the Hubble Sector. This sector consists of three distinct bubble universes expanding through an exterior mega-void:
  1. Hubble Universe 1 (Our Home): Currently expanding and hosting the stranded artifact Ceers-2112.
  2. Hubble Universe 2 (Where Ceers-2112 came from): A highly advanced, older universe that successfully evolved structured, metal-rich spiral galaxies prior to the cosmic intersection.
  3. Hubble Universe 3: A fast-moving, high-mass neighbor traveling through the northern sector of the mega-void, serving as a gravitational catalyst without making direct physical contact.
III.
Approximately 13.5 billion years ago (roughly 300 million years after the Big Bang), Hubble Universe 1 and Hubble Universe 2 experienced a hyper-luminal orbital scrape at a central origin point. During this collision, the fully formed CEERS-2112 was gravitationally sheared from Hubble Universe 2.
To account for its cross-sky displacement without violating local relativity rules, the model introduces a multi-universe gravity assist. As Ceers-2112 was pulled from its home, the extreme mass of the passing Hubble Universe 3 created a powerful gravitational draft. Acting as a celestial tractor beam, Universe 3 slingshotted Ceers-2112 at a localized velocity of 83% the speed of light (0.83c).
To avoid the catastrophic spacetime friction and atmospheric drag that would otherwise vaporize a galaxy moving through pristine cosmic gas, Ceers-2112 traversed its trajectory outside our universe’s fabric, using the friction-free vacuum of the exterior mega-void as a highway. It eventually dove cleanly into the northern hemisphere of Hubble Universe 1, safely decelerating into its current observed coordinates within the Extended Groth Strip.
IV.
Over the 13.5 billion years since the initial collision, the layout of the Hubble Sector has expanded to the following present-day vector positions:
• Hubble Universe 1 and Hubble Universe 2 have drifted in exact opposing trajectories away from the origin site at a rate of 450 billion light-years per billion years each, resulting in a current total separation gap of 12.15 trillion light-years.
• Hubble Universe 3 has raced northward at a hyper-velocity rate 2.2 times faster, moving at 990 billion light-years per billion years, placing its present location at 13.365 trillion light-years from the original crash site.
To prevent future catastrophic impacts or complete isolation within the sector, the universes maintain a state of Dynamic Equilibrium. The internal cosmic expansion rate of each individual universe bubble is perfectly synchronized with its physical drift velocity through the mega-void. Because the outer boundaries expand at the exact proportional rate that the centers drift apart, the physical buffer zone between the universes remains mathematically constant, creating an elegant expansion shield that prevents secondary collisions.
V.
For the Hubble Sector hypothesis to achieve confirmation, future deep-space surveys must isolate signatures that cannot be emulated by native dark matter. This model predicts:
  1. The Ghost Stream: The individual stars kicked loose during CEERS-2112’s initial ejection would undergo dynamic relaxation over 13.5 billion years, dispersing into a faint, wide, intergalactic mist. High-sensitivity future telescopes should detect a path of ghost-like, ultra-diffuse fossil dwarf galaxies tracing a straight line directly from the Eridanus Void to the Extended Groth Strip.
  2. Anomalous Mass Trajectories: Sibling galaxies pulled during the same event (such as REBELS-25 or Alaknanda) should display parallel “peculiar velocity” vectors that defy the general local flow of Hubble Universe 1’s standard expansion grid.
